This is a forum for ideas on converting some female High Elves to fit in standard units. Many of us have considered using maiden guard as proxy sword masters or phoenix guard so this is to be a bit more original.
Here's my idea currently in the works: female archers: http://jeffburjr.deviantart.com/art/fem ... -132663569
To get this far you simply cut off all the "leafy" armor bits and any other things you don't want there. And then you add then onto some archer bodies add GS for sashes and belts and the head can be whatever, although I'll use the wood elf heads just for the sake of ease.
Some female highelves ideas
Re: Some female highelves ideas
I made some female Silver Helms awhile back myself. I used Dark Elf torsos, SH legs and arms. The heads were a mix of archer and helmless RBT crew bitz. I gave them all topknots from the Warriors of Chaos sprue (I have a weakness for them )
The arms look a bit big for them but it works out in the end.
i quite liked the female high elf dragon rider back in war of the beard.
