kelzmeltzer wrote:
I like Alarielle quite a bit, and an infantry list benefits greatly from having her around.
A few of my thoughts on the specifics of yours:
1. Alarielle
-- What lore(s) were you thinking you would use most frequently here? High Magic for the ward saves? If Life, had you considered the Banner of Avelorn on the BSB?
3 from light and 1 from high 2. Mage
-- What was your plan for Metal? I like the lore, though the signature is tricky for a level 1. You’ll need 3-4 dice for the un-boosted casting (74%, 95% chance of successful casting), and 6 dice for the boosted version (73% chance of successful casting, which is a bit low).
In a tournament setting its useful to have searing doom to combat high armour. 3. Sea Helm
-- Will he be in the White Lions with Alarielle, or in with the Phoenix Guard? If he’s with Alarielle, the Shield of the Merwyrm may be unnecessary (he would have a 5++ already).
I did change this to a regular noble with banner of Averlorn4. Core
-- I think you’re a few points short here just based on what you have listed out – I’m thinking you put bows on the Reavers to hit minimum core?
yes, I did put bows on them. 5. Phoenix Guard
-- What was your plan for the Phoenix Guard? Did you want these guys to play a support role? In an uncomped environment, they may struggle as an anvil vs. a true deathstar (without character or magic support), so you’ll have to play carefully with them.
As I see it, you might benefit from tweaking your lore and magic item selection, but everything else looks otherwise sound!
If you wanted to radically modify your list, taking out the Phoenix Guard and going toward an Alarielle-White Lion Deathstar™ is competitive but defensive in playstyle (with appropriate support from Rare - i.e. more bolt throwers and/or a frost phoenix). All down to preference.
Hope that helps and good luck!
Thanks, I did play a game last night against an Empire list with 3 units of demis and the rest of the army being knights, backed up with light magic. I was easily beaten! I had some bad dice rolling but it did highlight that my elite troop units were too small, maybe should have gone for one big block.
It also opened up my eyes to what I can expect in an uncomped environment and will probably have to match this, anyone suggest a really tough list I could use?
