Best way to remove old paint?
Hi all! So in my younger years I decided to paint some of my miniatures, but looking back on them now ten years later I can see that I made many mistakes. I was wondering what the best way is to remove the old paint without damaging the model, or if that's even possible. Thanks!
Re: Best way to remove old paint?
Dot 4 break fluid.
de naturated alcohol is great when stripping plastics
- grantmepower
Simple Green works very well. Let a mini soak in it for a day (less if you get the concentrated stuff and you're stripping plastic), then scrub with a toothbrush.
- Very Helpful Elf
Simple green (nicer to work with but a bit pricey) or Brake Fluid (awful to work with, but dirt cheap) for plastics. I prefer acetone for metals. If it''s fine cast then best I can tell is that you are out of luck.
- Location: Where the sun don't shine.... Holland, that is...
Since he painted the models 10 years ago, it's probably not finecast
Plastic: break fluid as described above.
Metals: Thinner (not turpentine) Don't use in your living room cause the stuff is horrible. Just let your models soak in it for a few days and get a toothbrush. Don't forget to remove any plastic bits before dropping them in cause the thinner will turn plastic to goo.
[quote="Tyrion Reaper in a topic about murder"]I would therefore be very careful of ever annoying Caladaidoomblade as he has thought this out and you might go missing without a trace
[/quote]
[b]Hell is other people
- Sartre[/b]
[/quote]
- Sartre[/b]
What the other guys said. The main thing is that there is a difference between plastic and metal models. Plastic is a lot less durable and as such suffers a lot more from more aggressive methodes. With simple green for instance, you can leave models in there for a long time and not notice any adverse effects (it's basically a form of green soap if I understand correctly). Break fluid, you don't want to have a plastic model in there for longer then you have to. Metal models care a lot less about this.
- Very Helpful Elf
We are getting close enough to 10 years on with finecast (it's been 6 I think) where if people are going by memory or just guesstimating it could be finecast.
Also, I always type that hoping someone will correct me. Seriously, if anyone knows anything that works with finecast please tell me.
- Very Helpful Elf
Well, that and some of the chemicals "melt" the plastic. Acetone and thinner will do this quickly. But, I've actually left plastic models in break fluid for 3+ months (I forgot about them). Other than some discoloration there were no ill effects. I probably still wouldn't recommend anything over a week though.Prince of Spires wrote:What the other guys said. The main thing is that there is a difference between plastic and metal models. Plastic is a lot less durable and as such suffers a lot more from more aggressive methodes. With simple green for instance, you can leave models in there for a long time and not notice any adverse effects (it's basically a form of green soap if I understand correctly). Break fluid, you don't want to have a plastic model in there for longer then you have to. Metal models care a lot less about this.
Rumour online has it that GW has changed the formula for finecast as few times. Which is why stuff that works for one person turns models into goo for the next one.Shannar, Sealord wrote: Also, I always type that hoping someone will correct me. Seriously, if anyone knows anything that works with finecast please tell me.
Simple green seems to be the most common solution, though the advise is not to leave the model in it for too long. Some people had success with Detol, break fluid or oven cleaner. But for others that resulted in wobbly figures (mainly extremities of models).
Some of my elf horses have been having a bath for 2 years now - should I be concerned?Shannar, Sealord wrote: I probably still wouldn't recommend anything over a week though.
- Very Helpful Elf
Honestly, I think you are fine. I just don't want people getting annoyed with me, and a week should cover what you need.RE.Lee wrote:Some of my elf horses have been having a bath for 2 years now - should I be concerned?Shannar, Sealord wrote: I probably still wouldn't recommend anything over a week though.
- Very Helpful Elf
A few years ago I tried a bit of sprue in WATER and it swelled up a little. Break fluid made it expand like a sponge.Prince of Spires wrote:Rumour online has it that GW has changed the formula for finecast as few times. Which is why stuff that works for one person turns models into goo for the next one.Shannar, Sealord wrote: Also, I always type that hoping someone will correct me. Seriously, if anyone knows anything that works with finecast please tell me.
