It is currently Wed Apr 08, 2020 5:37 pm
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2
PostPosted: Sun Mar 23, 2014 12:02 pm
I love what you've done with the Sisters of Avelorn conversions. The first army I assembled was for Avelorn and i still have a soft spot in my heart for Avelorn even now.
It seems to me that GW left it far too long to create an update for the old Maiden Guard figures, but at least they've done it now so I can't really complain.
PostPosted: Sun Mar 30, 2014 2:19 am
Thanks for the comment Wilda, I still love the old maiden guard however. My next unit will be about them.
In the meantime , some of my projects are finally done! Finally, a pledge complete :roll:
A quick update of the steel movement tray once painted and decorated:
Khoril finished:
Image Image
The white lions:
Image Image
Image Image
It took me a lot of will power to get back in the saddle after my cat rampaged through my figurines, but I am pretty happy about the results. :P
A tale of Ellyrion, cavalry army blog:
viewtopic.php?p=749457#p749457
Painting log:
viewtopic.php?p=816029#p816029
"We ride until the sun sets..."
PostPosted: Sun Mar 30, 2014 7:48 am
Great stuff - I've already complimented the bases, so I'll say how much I like the banner. Its not very elven, but goes really well with the feral White Lions!
PostPosted: Mon Mar 31, 2014 12:57 am
Spectacular autumnal feel to your army :D
I really really liked the way it worked on Alariellle.
PostPosted: Thu Apr 03, 2014 1:59 am
Thank you very much guys, my wife tells me I should only do basing and forget painting :P
I`m slowly learning new techniques however, might be still hope for better color blending and highlights.
On the White Lions Banner, it`s elven alright but dark elvish in fact, from the black guard standard bearer :twisted:
I`ll try to get around and maybe put a design on it, it was intended at first as a scarecrow or lichebone banner.
My new project is an elven lady, Lucinda ( or Lucia ? ), to use as a mounted noble or princess.
The body was carved out of greenstuff, I still need to work a bit on it.
I already had time to drill holes and place mini magnets as I intend to have inter-changeable arms and items.
Here you can see the great weapon arm magnetized, which allows some different poses.
Image Image
For accessories, I plan a great banner, star lance, halberd and shield arm.
Painting log:
PostPosted: Fri Apr 04, 2014 10:28 am
You carved her body from greenstuff; - RESPECT =D>
PostPosted: Sat Apr 05, 2014 2:52 pm
Here is some progress, with a magnetized head, shield arm and to be star lance.
Wilda, it is not technically entirely carved. It`s a mixture of greestuff mold with my own carving for the collar fur,
arms sockets and the waist belt dragon plates to match those of the lower body.
But I am definitely having fun with greenstuff, I did not fancy the lady with that above sister head, so started to work on a new one:
Painting log:
PostPosted: Sun Apr 06, 2014 7:04 pm
Lucinda still in progress, I initially planned to add some kind of gold net over her poney tail, might have to let them flow instead. Not too sure.
Also, how I will tackle the 2 "balls" of hair. Probably have trouble decide if I add a jewel on a silver band. Anyways, been tough to think and work with the chaos at home. :?
Image Image
Image Image
Painting log:
PostPosted: Mon Apr 07, 2014 5:12 pm
Work continues, I am fairly happy with results so far.
I will try get better shot of the head later but I never thought I could do this with greenstuff :)
Image Image
Painting log:
PostPosted: Tue Apr 08, 2014 2:14 am
Well, I deem the head finished for now, it was a lot of work:
Image Image
Image Image
Painting log:
PostPosted: Tue Apr 08, 2014 3:07 am
Centurion
You've got talent sir.
X-wing Blog
PostPosted: Thu Apr 10, 2014 11:21 am
What tools are you using when working with the green stuff?
PostPosted: Thu Apr 10, 2014 2:06 pm
My greenstuff skills extend to repairs and filling in gaps, but this is on an entire new level. Well done! =D>
My painting log
My battle reports
PostPosted: Thu Apr 10, 2014 10:56 pm
Thank you guys :oops:
Well, that is my first attempt in fact, it has yet to stand the test of painting it. I suspect there will be imperfections revealed,
I know the torso was not so perfect but I was able to compensate with a bit of free hand painting.
For the tools, I`ve used my fingers, a magnification lense, cheap 99 cents hobby knife and a plastic spear bit. Also tweezers I stolen from my wife`s makeup kit #-o
Also a tiny pinch of water on my fingers when manipulating the greenstuff so it did not stick.
Technically, It was not a sculpt, as I was kind of adding part after parts like the hairs, the poney tail, the jewels and fan, with finally the net made up from strings. In short,
you do your frame, put the basic forms on it, wait for it to dry, add texture parts to it like a skin, wait for it to dry, etc... I kept a sister head nearby as a scale comparison.
The sculpting part was mostly the straight lines and chopping of parts and pressing them to stick on the head. With a skin like hair, you can compress or curve it afterward.
Ideally, I should have a tiny tiny grinder to sand and smooth it. Anyways, now I read this, might have been easier to just sculpt the whole thing straightforward :lol:
Painting log:
PostPosted: Fri Apr 11, 2014 1:00 pm
I found a nice blog here , think I’m going to get some of these tools, notably the silicon brush he mentions at the end. For the spoon and blade knife, I guess the spear bit and cheap hobby knife did the same job for me. Ball points and shaped forms like the pencil ends should prove easy enough to find.
http://natfka.blogspot.ca/2012/05/how-t ... kills.html
It also seems it is actually better to go with layers like I did instead of trying to sculpt in one go. So my instincts were correct. Main reasons he cite is that:
-It gives you a firm form to press against, which makes it easier.
-It preserves details you finally got correctly after an hour. In short, you let it cure before going around with other details and risking messing up what you have done.
- You won’t have to compete with the work/curing time when going step by step. Translation: be patient. I took 5 days at 1 hour per session, luckily in my case it was not discipline but rather luck since I only do have 1 hour spare time per day :lol:
Painting log:
PostPosted: Tue Apr 22, 2014 1:44 am
A bit of progress, first layers are done:
Image Image
I had to retouch the forehead since after a bit of paint some details were revealed wrong, notably from her profile the forehead did not looked correct.
So I added the tiara made of a triple layers, a bit like a rose.
I`ll add back the "fan" in her hair, as I`ll need to reglue it later.
I`ll post some more update of the body and other accessories.
Painting log:
PostPosted: Tue Apr 22, 2014 2:03 am
This is gonna be a wonderfully unique model!
PostPosted: Tue Apr 22, 2014 9:43 pm
Nice work. Greenstuffing intimidates the hell out of me.
PostPosted: Mon Apr 28, 2014 2:19 am
Thanks you for the encouragement, really helps keeping going on :)
Ptolemy, I`d say your painting skills are leagues ahead of mine and I`m sure after playing with the greenstuff a bit, you`d produce marvels.
So here is the lady with 90% painting done and 2 arms accessories magnetized to her body.
Image Image
Image Image
I still have the interchangeable great weapon, lance and shield arms to paint. Also the pictures/symbols on the banner, and of course the basing and a bit of highlights/shadows to really wrap it up. Ya... let`s say 70% #-o
Some stuff I worked on: I`ve added an elbow gold plate, also a rose between the banner arm shoulder and torso, I added an open back feature on the torso just under the fur cowl, also a similar heart shaped one on the front. The neck was a real pain in the... well, neck, to work on and I decided to glue it permantly.
Painting log:
PostPosted: Mon Apr 28, 2014 8:45 pm
I'm amazed at that Findolfin. That is such impressive sculpting on your bsb and a nice paint job to boot! Well done that man =D>
PostPosted: Sat Jan 03, 2015 5:53 pm
Thanks for previous comments guys, sorry if I was late, it`s already been more than half a year I touched a brush but after a long time, I finally was able to get some paint done.
Old models I had bought when I started, most of the silver helms had bits of old paint, broken parts and some glue deposit. I did what I could to salvage them.
This is a picture of work in progress:
Painting log:
PostPosted: Sat Jan 03, 2015 5:54 pm
And one of them almost done, short of shading/basing:
Painting log:
Users browsing this forum: Google [Bot] and 5 guests
