First attempt at making a competitive HE list with no special chars.
DP on Star Dragon - Vampbraces of D, Armour of Calaedor, Sword of Might
Noble - BSB, Battle banner, barded steed
Mage - Lvl 2 Scroll caddy
2x10 Seaguard
2 Lion Chariots
7 Swordmasters, Full command
7 Dragon Princes, Full command
3 RBT
2250 Competitive
Its hit or miss, there are some armies you will defeat very easily, and some that will defeat you very easily... vampires, tomb kings, dwarfs, skaven, anything with the magic or firepower to bring your dragon down.
Im saying the dragon is alot of points that easily can get swamped by hordes of static Cr, but as long as you pick your fights and never allow the Vampire or Khemir player outmanouver you, combo charge the weakest target and smash it, rince repeat.
If the opponent knows his armys strenghts he will keep his battle line tight, and hence wont allow you to break through without him getting in support charges.
But if your patient sooner or later a target will show it self.
My tip if you decide playing a star dragon prince, is to use the breath weapon first a few times before you go in for the kill, remove a few ranks, sowe some dissorder.
And try too allways put atleast on other character/champion in combat with the dragon, freshly raised champions is such a pain.
Im not saying its a liability. Sometimes it wins games on its own.newsun wrote:So your saying the Dragon is a liability then?
My point is that a star dragon's performance isnt consistent against different armies.
