I'm going to agree with this.rdghuizing wrote:I'm getting pretty exited about the whole thing to be honest.
From what I gather, The End Times is intended as a separate supplement to Warhammer. It is an extra set of scenarios with extra characters, rules etc. It also looks like it has a bit more to it then Storm of Magic did. They even gave the thing a separate logo. In that sense it feels more like what I expect 40K apocalypse to be like. Same core principles, just different ways of creating armies, different victory conditions and a different way to set up and play the game.
Do I think it will have an impact on mainstream tournament WH? No, none at all. Except for maybe allowing a new armylist in the Undead Legion. Other then that, I don't expect tournaments to suddenly change.
What I do think is that it will give a nice change from normal WH. Ever wanted to put 4 dragons on the table? Well, now it might just be possible (depending on core restrictions etc of course). Will it be optimal? Probably not. Fun? Definitely.
As a side note, if they do decide to merge prince and SD stats then the thing will be absolutely brutal. It will have virtually no weaknesses. Flying, ASF, WS7, S7, T7, I8, W10, A10, LD10, 3+ AS, 2+ ward vs fire before you start adding magic items? All the usual suspects don't work. No low I or S to take advantage of. High speed. And if you can still give the thing armour and magic items etc (and they affect the whole model), you can create some truly horrendous creations. You can easily have two of them in your army, give them a 4+ ward, 1+ armour save. They take something like 8 cannonshots to take down. Good luck with that. And then, you want extra attacks? Rerolling wardsaves? S8-10?
Also, the comparison to WL isn't completely accurate. Yes, you get 48 WL, but you are missing ASF, WS7, S7, T7, I8, flying. WL hit the dragon on 4+, wound on 5+ and have to get through a 4+ armour and 4+ ward save. That is 1 in 24 attacks dealing a wound. Or you need 240 WL attacks to kill something like that. On the other hand, the SD (with armour of destiny, sword of strife and dragonbane gem) with 12 attacks does 14 wounds (if you include thunderstomp and breathweapon). Yes, the lions are stubborn, but that is a huge difference in damage output.
Even more so because the SD has one more advantage over the WL, and that is force concentration. The SD can hit pretty much anything on the table it wants on a very small frontage. Just imagine what 3 dragons can do barreling into a unit (2 SD and 1 dragon mage). Or perhaps 2 and a frostphoenix (incidently, with a frosty in the mix, the WL would need about 700 attacks to kill the SD/prince combo).
I mean, come on, this is my first post in a very long time on this forum. The End Times are coming and I'm home again.
Edit: Actually, it's really been quite sad over here for WHFB. The meta has completely died in my area, no one is really playing WHFB or even much 40K. Everyone has made a full transition to X-Wing, Warmahordes or some other game. After working a couple of months on OT, we finally released Diablo 3: Reaper of Souls on console, but there's not much movement on the high-fantasy side of things. The only meta I really have now is on UniversalBattle, and I haven't been on that in ages.
I want to get back into playing the game, but it's getting harder and harder to get something going.
